Deletes a network to be originated from this router.
| address-family | Specifies an IPv4 or IPv6 unicast or multicast address family. |
| all | Specifies all networks for the specified address family. If no address family is specified, all networks for all address families are deleted. |
| ipaddress/masklength | Specifies an IP network address and netmask length. |
N/A.
If you do not specify an address family, this command applies to the IPv4 unicast address family. To apply this command to an address family other than the IPv4 unicast address family, you must specify the address family.
If the specified address is an IPv4 address, an IPv4 address family must be specified with the command. If the specified address is an IPv6 address, an IPv6 address family must be specified with the command.
The following command deletes a network to be originated from this router:
configure bgp delete network 192.1.1.12/30
Support for IPv6 was added in ExtremeXOS 12.6 BGP.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
